Solar panel question
peter2407
11 Sep 2008
Picked up a second had solar panel for tuppence not sure that it works. Is there a way to check this without going through a palarver of doing a full installation? Thinking of volt meter approach.
As sugggested a voltmeter check is the first and simple thing to do....... but in bright sunlight! Expect up to 18 volts or more.
If you know the make and its a reputable one you should be able to find all its specs on line, one of which will be the max open circuit volts to expect.
If you get a reasonable volts reading, the next stage is to rig it up to an appropriate load and measure both volts and current. Look to see how the readings compare with the spec figures or for a similar size panel if you dont know its pedigree.
At least measure the maximum current you can get by simply connecting to an ammeter with a suitable range. It'll be big panel to exceed the 10amp range on most cheap multi meters!
Many will be horrified but the best test is to connect (short term) an ampmeter directly across the terminals. This should produce your 4.8 amps in bright sunlight. In winter sun a few amps will mean it is good.
A solar panel has in effect an internal resistance which in the case of this panel appears to be about 3 ohms. The output current can not exceed the rated 4.83 amps so shorting the panel output will not harm it or produce any more than 4.8 amps. Unlike a lead acid battery whose internal resistance is low suchy that a short will cause high current and harm.
good luck olewill
