Trundlebug
I fitted a semi flexible 150w solar panel to my sunroof over the winter, after extensive research and planning.
The panel I fitted was this one http://www.titan-energy.co.uk/150w-flexible-mono-solar-panel-122-p.asp
To make the most of its output and wary of the many cheap ebay pretenders I bought what I thought was a reputable charge controller for it, and suitable for its (hopefully) over 10A output. http://www.victronenergy.com/solar-charge-controllers/mppt-75-15
Well on our recent fortnight's holiday to Wells next the Sea I had the time, opportunity and weather to properly evaluate its performance, repeatedly as the weather was superb.
The maximum charge current I've seen is 6.0A.
One day in very early July, 1pm, FULL sun almost overhead (not a cloud in the sky) its output was a meagre 5.5A. I know if I'd started the engines they would have charged at 14.4v and around 15A at the level of discharge of the batteries at that time.
Now I know the output falls off with higher temperature (and it was one of those really hot days a couple of weeks ago).
But I worked out that my 150w panel was producing 82 watts. With a proper MPPT controller.
Does output really fall off that much? i.e. 45%?
I never expected to get 100% efficiency. But I did expect from everything I'd read to get 8-10amps and maybe slightly more.
Originally I thought 150watts, 13 volts equals more than 10 amps (11.5) so that's why I went to the extra expense of a 15 amp charge controller. If I'd known it was going to be so low I could have saved quite a few bob and bought a 10A model.
Has anyone else fitted this combination of panel and controller?
What has your experience been?
Am I right to be disappointed?
