Petronella
I have two solar panels mounted on port and starboard rear guard rails. One is 100W, the other is 80W. Normally they give around 5A each in good sunshine.
Recently the output of the 100W panel has dropped so that it rarely exceeds 1.5A whilst the 80W panel is still showing 4A-5A (although VERY occasionally the 100W one will VERY briefly show up to 4A-5A). Open voltage is 20V, open current 1.5A.
I have worked back through the cabling and connections and everything seems fine. However if I connect the suspect panel direct to the battery I still only get a reading of 1.5A max. I therefore deduce that either the panel or the diode connections are faulty. Is this a correct deduction?
If so, can anyone explain how I can bypass the diodes to eliminate them from the system and hence hopefully prove that they are the problem? When I take the cover off the "diode box" on the underside of the panel I see four "wires", one coming from each row of cells. The outer two are connected to the positive and negative leads out to the battery (via the MPPT controller). All four"wires" are also connected together with a diode (3 in total) in line between each pair. What needs to be connected to what to bypass the diodes?
My understanding(?) is that I don't actually need these diodes anyhow as the output is fed to the batteries via a SunSaver MPPT controller with its own blocking diodes so if it is the diodes causing the problem I could remedy things by simply bypassing the panel diodes. Again is my understanding correct here?
This is at the limit of my electrical understanding so please be gentle!
Thank you.
Thank you.
