zoidberg
It is easier if one sits at home & sews some webbing to a ring whilst watching Eastenders then if one puts a loop on the other end of the webbing one can thread it through the sail & fix a shackle with the block on it. This saves any sewing at the boat.
I'm tempted to offer nothing but foul abuse and ridicule to someone who watches Eastenders when there's all the drama, fascination and entertainment of watching paint dry available.... but here goes.
There's no need to actually SEW tape to a ring, although that's an option. Instead, sew or tie a loop of the required length. That can now be attached to the s/s ring by means of a Cow Hitch. At the boat, pass the other end of the loop through the tack or reef-tack eye, and also use a Cow Hitch to attach the second ring.
One could also make the loop from single-braid Dyneema, with an easy loop-splice. There are several vids, e.g.
Also, should one use a Barton or other High Load Low Friction Ring, then a cordage downhaul is also easy to rig and adjust.
You're welcome.....
