Lucky Duck
Fine if you are ‘laying up’ for some time but the boat is in commission all year round
Fair comment.Fine if you are ‘laying up’ for some time but the boat is in commission all year round
Don’t let patio magic go down the drain, it wipes out aquatic life. I’d wash first then spray patio magic second.
It’s more toxic to aquatic life than detergent and persists much longer in water treatment plant sludge. I was referring to it getting into a washing machine, which was the subject. I assumed on land.
Certainly yes in Scotland around the areas that are near the deck. Hence a little brush with Patio Magic occasionally which sorts the problem.Fair comment.
Do you find you get the same sort of "greening" if the boat is used regularly?
In commission doesn't always mean in use. Ours is in commission all year, we live on board. We still only sailed once between end of Oct and end of Feb this year due to extreme and constant weather so our ropes are green on the deck. As Dunedin said, a little patio magic when cleaning the deck sorts it out, and the deck was green too so needed doing.Fair comment.
A late club member told me about a rope-cleaning attachment he had for a pressure-washer. He described it as a T-shaped plastic affair where you passed the line through the cross-piece with the washer attached to the base. I never got to hear about any results, though I think he had used it.It's tempting because it cleans the rope instantly, but it really wears it. Also, if done over a randomly coiled rope one ends up with banded ropes like Venice "paline"
No greening on ropes on my boat based on the Clyde, generally happens to boats which are left standing for long periods.Certainly yes in Scotland around the areas that are near the deck. Hence a little brush with Patio Magic occasionally which sorts the problem.
Much better to use it for its intended purpose. It has a half life of between 5 and 17 days in soil. It degrades slower in sludge in water treatment plants because it’s anaerobic. The danger is to aquatic life because it’s an algaecide. It doesn’t affect plants.Seems it might be too dangerous to use on paths, drives and, er, patios, where it will drain off and get into the soil and eventually rivers and/or water tables?
How does one properly use and dispose of the stuff, I ask as owner of a small container of the stuff?
Fair comment.
The renovo is heinously expensive but cheaper than new running rigging and I was seduced by the pbo test. I did not get magic results from soaking or soaking + washing. Less green yes. Not green no. As an experiment I left my kicker soaking for a week. That didn’t work either. And the stuff has a rather unpleasant smell.1. Renovo Marine Rope Cleaner worked okay, soaked for a few days then rinsed in the washing machine on rinse only cycle.
I used to use a bungee tie to lift them off the deck on Dad's boat. On my boat I changed how they are attached to the car so that I can remove them when the boat sits for any length of time. They used to be spliced directly to the car, and one winter just destroyed them.The control lines for the jib cars are the worst, not helped by the boat having full length jib tracks (for no obvious reason as the standard sail plan is a 106% jib) which channels the water along their length.
The boat next to us in Haslar has done this, it took me two days to work out what the pipe was for!A bit of PVC piping cut in half and pushed under led aft control lines (or any other lines that need to be kept of the deck) works well. Doesn't look super elegant, but it is effective.
I meant when used as instructed on the product. It kills single cell organisms by disrupting the membrane. In normal use it doesn’t scorch the plants around a patio.(Incidentally up-thread somewhere its stated Patio Magic doesnt affect plants. This is unlikely too, since algae are plants.}
Yes, I suppose higher plants are better protected, waxy cuticles on leaves and such. Id expect roots to still be quite vulnerable, but some of the stuff probably binds to soil, and sub-fatal root damage might be unseen anyway.I meant when used as instructed on the product. It kills single cell organisms by disrupting the membrane. In normal use it doesn’t scorch the plants around a patio.
Benzalkonium chloride is in a vast range of products - eye drops, nose drops, mouth wash, athletes foot cream. I’m only saying it is best used according to the label.
