Blue Seas
Thanks to this forum I have now got the 24v battery bank charging issue sorted (Thanks Paul Rainbow & Geem in particular
I've now started to sort (untangle) all the wiring and would appreciate comments on what kit to buy to permanently mark the wiring at each end.
The good news is that all the negative cables (about 150 of them) are black and all return to one small locker adjacent to the fuse/switch panels. The rather less good news is that the positive cables are also black (another 150 or so) and not a single cable is marked. It's as if Medusa had invited all of her worldwide family to a marriage celebration resulting in a snakes wedding of biblical proportions in a small dark locker near me. I have spent two full days stripping out so far and I've hardly scratched the surface.
So, two questions if I may,
1. What is a decent, readily available and reliable cable marking tool / system? (mostly 1.5 - 6mm)
and,
2. Any thoughts on me fitting separate negative busbar blocks (perhaps one in each of the seven bulkhead zones) and then returning just a few heavy negative cables rather than 150 individual ones?
The existing wiring is top quality, marine, tinned, flexible etc. and is totally corrosion free after decades of use so I'll try to re-use where I can.
Cheers.
and,
Cheers.
