Lakesailor
I've been rained off from grinding out the superfluous grp edges from the old floor beams. (not an enjoyable task at the best of times).
Old mouldings in hull. (They don't look too bad in this shot, but are about 1/4" proud of the hull and some of the mat is not very well bonded.
Once I have it clean I will bond in some floor beams and knees for the thwarts down each side (actually I think they are properly called seats).
The question is, do I install buoyancy?
The original boat had a floor above the water level and the void was supposed to be watertight and provide a great deal of buoyancy. If I install the floor lower I will have removable panels to allow bilge access. There is a small buoyancy chamber in the bow (which I could extend up to the foredeck) and a locker in the stern which I could make watertight.
However the boat weighs nearly 500Kgs. That would need a hell of a lot of positive buoyancy to keep afloat. 500 plastic milk bottles?
I could make ply lockers along each side with the seat on top and seal them to provide bouyancy. But the original design was supposed to be watertight and seemingly they all failed. Trapped water is worse than no bouyancy.
How water tight would it need to be? A small hole at each bottom corner would allow it to drain into the bilge, but would retain enough air to keep the boat afloat in the event of a capsize. Plastic bottles stuffed in the boxes would prevent too much water rushing in.
But I fancy an open look with the seats on knees and a clear floor.
This would afford much less buoyancy.
However:-
Apart from recovering the boat, what benefit is buoyancy?
I must admit I like the look of open boats rather than those with built-in flotation.
However:-
- It's a heavy old thing so righting it after a capsize is probably not an option.
- It'll be mainly sailed on a freshwater lake. Rescue is not far away
- It's a big dinghy, so a total loss is not a big deal.
Open
Bouyancy
Bouyancy
