Siting a chart plotter
FullCircle
19 Nov 2003
It's three years old - Furuno. I don't need it to be out in the elements, cluttering up the cockpit, so that's where it isn't. When the boat is laid up I take it home, to spend the winter in a nice warm, dry cupboard.
Probably the same inate instinct that causes me to remove my 100m waterproof watch when swimming. Just an old habit, but waterproof seals have been known to fail, or is this now a complete impossibility?
No, but you wasted your money.
Buy a 2 quid watch if you are going to take it off.
My chartplotter has been in the cockpit 7 years without failure , in all weathers. It has a rather faded cover, but it is fixed and cant be removed.
I can't get my boat into a cupboard, which makes it cold to work on in the winter.
Simondjuk
29 Aug 2007
World region
With viz down to 50m, short chop waves at 3+m high and narrow channels less than 300m wide, and 30kts of breeze I really enjoyed pre-chartplotter days when I owned an Evo 25. Kept a chart in a knee pad.
I like that I can take a minute out now to make a brew without getting paranoid.
I am reading Roger Taylor and find myself not agreeing with some principles
I must be getting old.
You make tea while the autopilot and plotter do the pilotage?
Simondjuk
29 Aug 2007
World region
Maybe I'm missing something, but I don't really see the point of a chart plotter in the cockpit.
They, or the charts, or the changing geography mean they are not reliable enough to be trusted for pilotage. I've seen the boat icon placed on the shore, sandbanks, rocks, and numerous other places it shouldn't be when I know from transits and soundings that I'm actually where I want to be. Had I put the icon in the right place on the chartplotter, I'd not have been where I wanted to be, possibly aground.
Using them for passage making doesn't make sense as if you follow the line or just aim at the waypoint, you sail far less efficiently than if you sail a calculated course to steer.
If I'm not using it at either of those times, which leaves little else, then what's the benefit of having it in the cockpit?
What am I missing?
Heckler
24 Feb 2003
Small backup chartplotter in the cockpit?
I have the large chartplotter in the cockpit, and the small (backup) one down below, so it correlates to the paper charts.
Why, pray do you feel the need to keep your equipment where you cant see it in times of visual need?
+1, coming around St Davids head, ramsey sound etc, why keep popping below to check the plotter when I can watch it from the wheel!
Stu
johnphilip
15 Nov 2005
Naffpod
Try this for a home made version of a pod. Hardwood strips biscuit jointed together to form fascia and a waterproof electric box with the bottom cut out to house the back of the plotter and cables.
Heckler
24 Feb 2003
What am I missing?
The first time going north through jack sound from milford on my mates boat we eyeballed it through. I checked the down below raymarine chart plotter, it was accurate to within yards. When i went through on my boat, i had the plotter by the wheel, i did eyeball and chart plotter, again spot on.
Stu
Simondjuk
29 Aug 2007
World region
Stu
I'm not saying there will always be an error. Sometimes a plotter will show that a boat is on the side of the pontoon it actually is. Sometime though, there are big errors, so they shouldn't be blindly followed for pilotage. Transits and soundings cannot lie, the plotter can.
FullCircle
19 Nov 2003
What am I missing?
So you somehow feel that your paper is more accurate? Viz,viz,viz. Oh,and depth, although that is also visual in poor weather. The waves are a bit whiter where there ain't much water, and the noise is a giveaway too.
Simondjuk
29 Aug 2007
World region
Depth is visual? Now I'm really confused. I've never experienced visibility so bad that I couldn't read the depth sounder. I can get my face within inches of the screen... and they're generally illuminated.
My paper? What's that supposed to mean? You don't approve of paper charts so sneeringly call them 'your paper'? Very peculiar and rather unnecessary, but each to their own I suppose.
Anyway, if someone could tell me what I may have overlooked in not finding a plotter in the cockpit beneficial, given the caveats mentioned previously, I'd be grateful.
FullCircle
19 Nov 2003
No, depth is on your chart. Work out where the tide is, and you should be very aware of where you are not by the contours.
The depth is not necessarily on your little whizzy counter. Round here it is visible to the naked eye, with practice. Add that to your positon on the chart, and it is very good for the soul.
Your paper is my paper and you misunderstood my meaning. The paper charts are no better than electronics, as the banks and depths are movng all the time. In one instance I observed a 2m depth shift in 8 days of gales doing the same route.
I was able to observe it was the same route, because it was still on the chartplotter from the week before.
There is another recent depth shift issue on the East Coast forum, except mine was avoided, by luck, possibly.
Take all aids for safe passage, and make your decisions on all available info.
Simondjuk
29 Aug 2007
World region
The depth is always on my little whizzy counter. Adjusted for tidal height, it's probably the most infallible guide to what actually matters, water under the keel and where the deep water lies, that there is. But that's not the issue.
Given that it seems we're agreed that the plotter can be as useless as the charts in areas where the geography is rapidly changing, what is the benefit of having a plotter in the cockpit if it only tells you what was where when the survey was performed, which is likely to be as long ago as it was for the paper charts? That's all I'm trying to establish. Other than the plotter perhaps allowing the use of recently placed waypoints which may not yet be outdated by shifts in the sea bed, I see no benefit, and even then you have to somehow place those waypoints without them there in the first instance, at which time you don't have them so the plotter is no use for that... and around it goes.
Richard10002
17 Mar 2006
Manchester
This is a "no brainer" as they say.
Absolutely no point having a plotter down below if it's the only one you've got - a repeater perhaps.
Given that the plotter display is effectively a chart right in front of you whilst helming or conning during pilotage, it's easy to establish whether the icon is in the right place or not, and much quicker than going below to check either the paper charts, or the plotter.
I agree that, if you blindly assume that the icon is correct at all times, with no additional checks, that could be a recipe for disaster on the rare occasion when things go awry with the system. However, armed with binoculars, hand bearing compass, a prepared pilotage plan, the additional benefit of a chart plotter immediately to hand, as an additional "aid", is almost immeasurable. As long as you are aware of the potential pitfalls and problems, and are monitoring the situation properly, there is no more, or less risk in using a chart plotter at the helm than any other navigational aid.
'To wit' radar - not to be relied on to the n'th degree, but bloody handy in fog etc.
For those who worry about electronic, or system, failure, I presume you employ a man with a red flag to walk in front of your car :)
We've landed on the moon, Aircraft take off and land automatically, cars park themselves, and so on.
Of course, on my little narrow boat, a chart plotter at the helm would be overkill - I tend to use Google Maps these days :)
Live and let live, and each to their own and suchlike
To the OP - iirc, the Navipods are around £250 or so but they do the job properly. Anything else will likely be cobbled together and not quite satisfactory. In the scheme of things, £250 isn't a great deal, and I'm sure it will repay its cost in spades.
In my case, starting without a plotter, I bought a cheap waterproof Lowrance job with a hi-res 5" screen which saw me from Glasson Dock to Malta and back. Mounted at the wheel on a swivel, and removable, the only thing I might have done differently with hindsight is to invest in Navionics charts, rather than rely on the cheap Transas charts that came with the plotter.
There is no way I would be without a plotter at the helm these days!
Richard
prv
29 Nov 2009
Southampton
Each to their own then, as you say :)
I bought a plotter last year, having never used one before, and found I didn't like it. Rather disappointed, especially after spending what felt like quite a lot of money on the device and charts.
Interestingly, despite my mum being indifferent to the idea and my dad actively opposed, I believe they now use it every time they go out :D. Whereas when I use the boat, it nearly always stays on its shelf in the cabin.
Simondjuk
29 Aug 2007
World region
Richard,
If I'm using all the rest of the tools, as you suggest, I don't see the need for the plotter. To me, pilotage is something done by looking out of the boat, not into it.
Your post did make me think of a reason though, to provide radar info at the helm.
I've just not found it's something I look at in the cockpit on boats that have it, and that others, particularly novices, tend to be glued to it like there's a blockbuster film being shown. :)
Koeketiene
24 Sep 2003
Le Roussillon (South of France)
www.sailblogs.com
Thinking about putting it on the side of the cockpit to the left of the helmsman - anyone done this? Successful or not?
Never seen it, but I'd worry about it getting kicked, or stood on when the boat is heeled over.
We have VHF CommandMic, GPS repeater and AP there, and they seem to survive OK.
Though we never sail at rediculous angles ;)
