Ohlin Karcher
N/A
Yes, Mayday straight away, then it's done and you can crack on with whatever method. You can always cancel the distress.
How about stopping the boat with a parachute? It works with small planes.
This has been tested many times, up to 10 knots with full sail. The chute slows the boat to 1-2 knots without the crew doing anything.
I'm sure someone will hate it, but prove why it can't work. Obviously, the intention was a true singlehanded situation, when there is no one on board.
Heave to and or stiop the boat in any manner avilable to the skill of the remainng crew
Deploy all flotation and markers .
manoeuver the boat to recover.
Recover any way you can, inc deploying the liferaft and hold the casualty alongside if necessary. Then call...
This bolleaux about going below to send radio messages and look ar the GPS is exactly that, bolleaux.
The first five minutes will determine if the mob is going to survive ot not; calling on the radio is never ever going to result in a rescue in less than three times that, more likely ten times that or more.
Wasting time while someone is drowning calling someone who will take ten minutes merely figuring out where you are and can't respond in an hour isn't going to help anyone, least of all the poor sod who's drowning. Don't waste your time doing it.
Survival is almost always determined by what you can do on the spot, not what someone you call can do an hour later.
First person to mention the life raft. Hoorah.
Disagree with the rest though. A mayday call is a top priority. If you have to go below to do this get your boat sorted out.
I would work on that assumption & not go overboard if at all possibleNormally there may be 'best options' for crew depending on sea condition, course/wind, land proximity, has MOBs LJ worked, has he a PLB/Ais beacon?
For a drill to be a 'conditioned reflex' these options can not be considered you just have to let your taught reflex's work.
My Dan buoy takes around 3 or 4 seconds to deploy ( from the wheel position) if sailing I would always make this my taught 'Imediate action' then stopping the boat followed by
pressing the DSC button.
In choppy water you can loose eyeball with the MOB and if your not experienced/speedy with the sails you may never locate him.
In choppy water you can very quickly loose eyeball with the MOB and if your not experienced/speedy with the sails you may never locate him.
You will be in the water anyway as MoB. The individual left onboard, does not need to be experienced/speedy with the sails if you stick to a very simple drill, as indicated #9
I keep emphasising that you should not leave the casualty, otherwise you will quickly lose sight of the him, yet am still amazed by posts suggesting all sorts of complex manouvre's, forgetting the only person left on board able to effect all these, is an inexperienced person who has been on a comp crew course, who will by now be panicking & possible traumatised.
Remember this is not a MoB exercise on an RYA course, with 4-5 crew helping.
The priority of a Mayday call varies according to the available help. I the Solent there's a great Heli and attentive coastguard; plus you're seldom more than 3 minutes from the nearest RIB.
Bit different in the Greek Islands.
The priority remains high. Effectiveness of calling may vary. Effectiveness of not calling does not.
The very simple drill in post 9 may be grossly flawed.
'simply pull the main in to centre the boom and put the helm hard over.
Some boats can go a @&%& long way in the time it takes a female novice to pull the main in all the way.
I mention female in this context simply because mine happens not to be a gorilla.
In that time, the boat might be going in any direction, or a random mixture.
My opinion is:
1) get the danbuoy/lifering set over the back.
2) stop the boat, if possible
3) Mayday.
4) attempt to meet with casualty at danbuoy.
But I think you have to tailor things according to boat, people and circumstances.
Why "grossly flawed"?
Have you tried it?
capnsensible has said that he, probably as experienced as any on here, teaches it & has used this method on many boats without any flaws, so must be some merit in it. You comment upon how difficult it would be to haul in a mainsheet to centre boom, yet seem happy that the same person could furl a headsail & drop the main, at the same time as sending a mayday & starting engine, all this from an inexperienced female in a panic situation.
You mention "stop the boat 'if possible'", how?
"Attempt to meet casualty at danbuoy", how?
When your female crewmember is doing all this, do you really think she will be eyeballing the danbuoy at all times?
A danbuoy is not the easiest to spot, unless a flat Solent seascape & she will be disorientated, not knowing in which direction to look. The "very simple drill", eliminates all that precisely because it is a "very simple drill".
