jwilson
The OP is talking about 1+1 on a charter boat: almost certainly a modern fin and spade type. The classic "crash stop" of tack immediately without touching headsail sheet may or may not work. Neither I nor two others on board, both YM Examiners, could do it on one racy 45-footer, even if you used the engine fwd and reverse to help. On some boats it can and does work though. With same people practiced it again on older long-keeler, with minor adjustment (waiting a few seconds before tacking) it worked beautifully, often didn't even need to start engine.
The suggested wheel hard over to tack and sheet in mainsheet option will keep most modern fin-keelers in a possibly quite violent endless tack/gybe loop reasonably close to the MOB, but with one inexperienced person left on board what do they do next, unless by pure luck the MOB can grab the transom on one of it's circles. In any wind the person left aboard will be struggling to keep balance and an eye on the MOB.
Given the OP's scenario, I'd say getting danbuoy and anything floatable in the water first, then roll up genoa and drop main on deck, then start engine, might be the best option to get back to MOB safely.
In the Med definitely press MOB button on plotter: I'm not entirely sure it's that valuable in a tideway. I don't think any plotter software is smart enough to calculate/estimate tide and steadily move the MOB mark position to compensate.
If MOB fit and conscious you have a chance. It unfit and/or unconscious one inexperienced person aboard has effectively zero chance. Even if person left aboard singlehanded very experienced, very very difficult indeed to retrieve an unconscious person except in really benign conditions.
