Single handed MOB drill
Further if you actually read the thread you will see that when scotty 123 pointedvout this as a esay safe method i agreed straight away with regard to the op.......
I agree.
I'd add time spent teaching one's guests the basics of handling the boat, particularly a sailing boat, is always rewarding and might make a difference one day.
I spent a couple of days with a couple of absolute beginners aboard earlier in the year. By the end of it, I reckon they'd have been good to get within 'Seattle Sling' range even if I wouldn't expect them to pick up a mooring first go.
I agree with every word of that :)
My instructions are
1) Throw dan buoy/life ring.
2) Helm turned in opposite direction as boom.
3) Press red button on helm radio mic.
4) try to locate dan buoy and get boat to sail around MOB to get close within the trailing line
Seems good to me. 1,2 and 3 are all pretty much instantaneous. And very clear. And, in the right order.
Who remembers this?
Tell them to press the button. It may not have helped as they did make a 999 call. But having the position and getting it out immediately may just have made a difference.
“The multi-millionaire disc jockey Chris Evans and a party of friends on board a yacht in the Solent were thrown into a panic when the skipper was knocked overboard and drowned.
Screams and shouts were heard as they tried to rescue the skipper, James Ward, who was floating face-down just under the surface.
One of the six party-goers dived off the 31ft Nausicaa, but failed to reach him in the dusk as the inexperienced sailors tried to stop the yacht. They could not operate the VHF radio and had to dial 999 on a mobile phone. When their call was answered, they could not manage to switch on the yacht's lights to guide rescuers to the spot.”
Who remembers this?
The Skipper (pubowner friend) had taken them for a jolly, but failed to give them any safety brief.
This was a Hamble-Cowes-Hamble trip & guests enjoyed a 'liquid' lunch.
Unfortunate.
PS, how many Solent sailors on a similar trip, in familiar waters, bother to switch their gps on, because they know where they are, rendering any dsc mayday fairly useless because no position is indicated?
Unfortunate.
Never. Because the VHF nags and nags if it hasn't got a fix.
(And anyway in my case speed and depth are on my plotter screen not on a dedicated device.)
Try helm over go back to mob and chuck them the safety equipment. That gets it in their hands not yards away fro where they are.
It works.
Really.
Unless the boat was...
* Sailing down wind.
* The boat was on autopilot and the second was not immediately at the helm. This is VERY common. It would virtually always be the case for me.
How many times have you tried it?
It doesnt take long to show even a novice to follow a few basic instructions and its a typical training scenario.
Push that button. Turn wheel or tiller that wa. Pull those two ropes. Cmon it aint rocket science and in just a few sessions this week i got 3 people well up to spec. Two had never been on a yacht before.
Its all about practice. Show them then do it. Over and again until you are both happy. All sports and hobbies need practice to get competency and confidence.
When threads like this 'bob' up Could it be that some posters lack a bit of confidence in their own abilities because they dont practice?
Do try it you may surprise yourself.
You are right about practice. And the OP was sailing with partner. So it’s relevant.
In a mobo my drill (if I’m at the helm ) is scream at pax to sit, come to neutral (sudden slop) and press red button, turn boat on the spot (spin the boat on its engines on twin shaft) and follow the wake back to the casualty. You can read all sorts of wise advice about Williamson turns to get back. Ok in a sports boat but not on a big shaft boat and my simple method works in any mobo.
Then put the boat upwind of the casualty with the wind bang on the beam. Drift down in neutral with a tick of the engine furthest from the casualty if needed to go forward or astern and he’s still in sight. Use bowthruster to stay beam to the wind.
I find it easy but I forget how hard it actually is without practice - when others try they really struggle with even figuring out where the wind is.
As said before if it’s non sailors on a day trip they get shown how to go to neutral and how to press the button. That will do I wouldn’t do the practice with every friend I take out.
Agree with all that except when I was taught to teach it on mobos, to initially go to tickover rather than stop with helm hard over. Just a tiny detail and it all works!
didn't quite understand that - I don't touch the helm at all so i won't stop with the helm hard over.
I spin the boat by splitting the throttles, if it's windy I'll wind some helm on as that increases the spin speed by a 1/3 or so and can help you get the bow through the wind but I don't normally bother, just leave the helm amidships. (this absolutely does not apply to out drive mobos!)
That's fine if you have 2 engines but most sailboats only one. I spin my single engine boat by putting the engine on tickover and helm hard over.
If you keep the engine at normal speed the turning circle tend to be larger. I was taught this to allow spinning the boat in a narrow channel or between moored boats in a marina.
The effective method I was shown with motor mob was throttles to tick over and spin wheel towards mob to kick stern away. Then as you say heave to upwind and juggle outbard engine throttle for recovery.
Worked for me on all kinds of mobo.
fair enough. I just don't normally bother with the wheel on bigger shaft drive mobos. Another thing do do for little gain, and the risk you'll forget and leave them over causing confusion later. My rudders do virtually nothing at tickover and nothing at all at less than about 6 knots out of gear. They are the size of a bit of A4 paper.
Understood Roger and all agreed but I was responding to his comment about mobos :)
