Rohorn
Singin\' Saildrives.Help please.
Hi....I just launched after fitting two new Yanmar 2Gm20F / SD20 saildrives in my cat, replacing the previous underpowered 1GMSD20s. New motors are super, and drives work well but at about 1900 rpm in gear a high pitched whine sets in. This noise frequency doesn't change with speed, the pitch (musical) stays constant, but gets more insistent as one goes faster.
Out of gear, no noise at any revs, so it's definitely the drives. They both start singing at the same revs. Coming from the gear industry years ago, I suspected a resonance in one of the components in the drive line, but Yanmar must have made many thousands of these things over about 15 years and I don't believe an inherent fault like that.
Dave at Yanmarhelp.com says it's probably coming from the propellers. I assume he means that the props are "ringing". They are bog-standard two blade Radice alluminium. I suppose one could try to measure the frequency while running (using my harmonica), then when stopped, nip over the side and tap the props to see if they ring at the same pitch.
Anyone met this phenomenon?
Cheers....R
Cheers....R
