Spyro
I've just fitted a simrad tp10 which is working fine until I try to use the Tack facility.
The boat tacks in the correct direction, the helm goes hard over then the tiller pilot reaches its full travel then goes into standby mode the result is the boat keeps on turning and if I don't intervine it will do a full 360 degree turn. I have tried simulating the tack in the marina by using the tack feature and turning the unit through 100 degrees while not conected to the tiller, if I do it before it reaches its full travel it appears to work ok. Has anyone else experienced this kind of problem? I thought I would ask before I contact Simrad.
