stranded
Following a recent thread in which I ruled out switching to LifePo I have taken a good look at myself.
I can’t get my head round the technical stuff but then I don’t need a state of the art installation- I don’t need more power, but I am very attracted to the lower weight (our battery box is part of the furniture and the only way I can fit 400+AH of agm is with 2xc.65kg batteries, which are not getting any easier to manhandle) It must of course be safe. Seems to my simple mind I might get away with:
1. Replace 400ah agm service battery with 200ah Renogy drop in LifePo with built in BMS: 12V 200Ah Lithium Iron Phosphate Battery w/ Bluetooth
2. Disconnect alternator feed (via Sterling charge splitter) from service bank and install DCtoDC charger from engine start battery to service battery.
3. Retain 400 watts solar via 2xVictron mppt controllers to LifePo (continuing to use Smartsense?)
4. Adjust charge parameters of Mastervolt Mass Combi smart charger/inverter (non-lfp model) to LifePo manufacturer spec (read something somewhere about switching to one stage rather than 3 stage charging?).
5. Adjust LifePo BMS to 12 - 14.2v range?
6. Install a type t fuse (whatever that is) <7” on consumer side of battery +ve
I am sure it can’t be this easy. But could it. Any complicating factors?
