Neeves
You don't define, fully, what your ambitions are for the switch to LITHIUM. You mention replacing Lead but you don't define what other ambitions you might have, like extending usage of the power for your galley.Following a recent thread in which I ruled out switching to LifePo I have taken a good look at myself.
I can’t get my head round the technical stuff but then I don’t need a state of the art installation- I don’t need more power, but I am very attracted to the lower weight (our battery box is part of the furniture and the only way I can fit 400+AH of agm is with 2xc.65kg batteries, which are not getting any easier to manhandle) It must of course be safe. Seems to my simple mind I might get away with:
1. Replace 400ah agm service battery with 200ah Renogy drop in LifePo with built in BMS: 12V 200Ah Lithium Iron Phosphate Battery w/ Bluetooth
2. Disconnect alternator feed (via Sterling charge splitter) from service bank and install DCtoDC charger from engine start battery to service battery.
3. Retain 400 watts solar via 2xVictron mppt controllers to LifePo (continuing to use Smartsense?)
4. Adjust charge parameters of Mastervolt Mass Combi smart charger/inverter (non-lfp model) to LifePo manufacturer spec (read something somewhere about switching to one stage rather than 3 stage charging?).
5. Adjust LifePo BMS to 12 - 14.2v range?
6. Install a type t fuse (whatever that is) <7” on consumer side of battery +ve
I am sure it can’t be this easy. But could it. Any complicating factors?
Kelpie started off with 270 amps - but then extended to 550 amps - to get him through a few dull days - but still occasionally uses gas (but also underlines some meals are better cooked on gas anyway). Geem has also extended his house battery bank.You can't really have too much battery capacity, the great thing about LiFePO4 is that it's very happy sitting around partially charged. One caveat is that you do want to get them up to nearly 100% every so often for the balancer to do its job, but that's not a big deal and you'll not really notice any imbalance if you're staying around mid charge anyway.
We started out with 270Ah and ran like that for about two years, doing almost all of our cooking electrically, as well as running the fridge and freezer. We recently increased to 550Ah which lets us get through a few days of dull weather.
We do occasionally still use gas, that's our main backup if the battery is low, rather than engine charging. There's also a couple of meals that better suit gas cooking. But cooking off solar power has slashed our gas use. We're still using the same 2.9kg bottle we bought in April, and we cook onboard every night.
If you want to extend the power available to the galley you will need to incorporate an inverter (maybe something else to drop hints about for Xmas). I might have missed this in your posts. The specification for your inverter needs to extend to what you have and also what you want (1500 watts for hot water) and 2000 watts for an induction hob (though you might find an acceptable hob you can run at 1500 watts). But a 1500 watt inverter will only allow you to use one device at a time......
It depends on your ambitions - but I think you will find your ambitions grow and a 200amp Lithium battery will quickly appear to be too small. I don't have enough experience but I think you will also need a bigger solar array. None of this directly impacts all the foregoing - and you might not find my comments sufficiently credible to act (but I'm simply pointing out what tiers have said, and done). So... you don't need to action anything other than your initial posts - but you might want to bear in mind you might find you need another battery (which wants to be the same size and make as the one your initially buy) and the inverter. (One recommendation suggested not only the same size battery but from the same batch - which seems a difficult one)
You might have followed my thread where I have built a Lithium house bank at home with a solar array on the roof. We don't find a 200 amp battery sufficient. Our 300 watts of solar is more than enough on a sunny Sydney day but get 3 days of overcast and the solar/battery are inadequate. Knowing the weather is going to deteriorate impacts your future (in terms of days) usage - as you simply don't know what solar you you will farm. One, I can assure you - many, might say my set up is 'ideal' and unrealistic for a yacht - which simply reinforces our idea that what it offers is inadequate. We can live with a 1500 watt inverter but will invest, in the fullness of time, with something bigger - not sure how much bigger.
The battery(s) you buy, according to Morgans Cloud, needs hard wired BMS in addition to Blue Tooth and must allow owner 'intervention' - so not simply displaying but allowing manipulation (but this might be standard for any blue tooth enabled BMS - but hard wiring is not provided on all BMS).
I don't know your Victron MPPT controllers, are they compatible with Lithium.
There is some excellent advice on Lithium here on YBW - you are in good hands. Watch for any contradictions - and query them, most, all, of those who have invested in Lithium are very supportive.
Jonathan
