stefan_r
- Joined
- 16 May 2001
- Messages
- 753
- Location
- Southampton & Greece (Chios)
I have a reserve fuel tank under a bunk that is fairly inaccessible.
I am after a cheap / simple / easy to install gauge for the tank…the tank does not have an inspection cover and cannot be opened, or more importantly cleaned from the inside – therefore what I need is something with the minimum ‘invasion’ into the tank to avoid too much stainless steel filings and cuttings appearing in my filters!!!!
Likewise the tank is under a bunk not leaving much space to cut a really big hole, clean everything and then put in a large gauge.
Something that just needs a hole drilled, sensor dropped through and then sealed with a couple of screws and some gunk would be great.
Frankly even a dipstick would be suitable because all I need is an occasional check to see is the tank empty / half / full.
Cheers
Stefan
mailto: stefan@athito.com
Cheers
Stefan
