Shroud boots
PabloPicasso
12 Feb 2010
Is it possible to fit shroud boots without disconnecting the bottle screws?
I was considering using radiator pipe cover sleeves as a temporary measure if not.
Doing one shroud at a time and using a spare halyard tied to the toerail as a backup, I’d be inclined to just whip each shroud off in turn and pop a tube cover on.
Shouldn’t cause too much issues.
If you do decide to do a shroud at a time. Make a diagram like the following before starting using a cheap digital caliper. That way you can loosen all the rigging slightly, fit your boots, then re-set the rigging to where it was before you started.
