Andy Bav
We have a manual overide on ours, so if the same type of unit you can do a number of tests for power etc before getting into the bowels of the system. We found that ours was an integrated float switch that worked intermittently.
We cleaned the unit up - it did have a load of crud around the impeller, but it was definitely a dodgy switch in the unit. We have since replaced the pump, and also wired in a water witch https://www.gaelforcemarine.co.uk/en/gb/Water-Witch-Bilge-Switch/m-5001.aspx as a secondary back up.
We also had another issue with our rear shower sump pump, which is a separate float switch and bilge pump. That problem was twofold.
1. The outlet pipe downstream from the pump was blocked - cleared by "jetting" out the pipe with a hose pipe, and
2. A dodgy float switch - which needed to be replaced.
Good luck. I think you will find this is a common problem regardless of age of boat and for me, now, will be part of my annual maintenance regime
