Should my antifoul be doing this?
White antifouling is an odd one...
On the plus side it is often the best colour on powerboats with a gelstripe as it doesn't clash.
But, white has a few downsides:
- Because the base, uncoloured antifouling is a brown sludge, a white antifouling will contain a lot more dye than other colours, hence it tends to be weaker. We tend to apply an extra coat of white compared to a darker colour
- Similarly, it is very difficult to get a very white sort of white: most whites are light grey
- Once launched, copper compounds (in particular) leach out and can stain the antifouling green
In terms of how an antifouling works, even a hard antifouling has to erode in order to work*: this exposes fresh algicide to give protection throughout the season. Thus, if you scrub an antifouling, flakes will fall off.
In general, a powerboat will require a 'hard' antifouling, which is more resistant to erosion and thus can cope with higher speeds. A yacht will usually require a soft antifouling, which would erode too quickly at powerboat speeds - but (in theory) a soft antifouling on a yacht should erode at the same rate as a hard antifouling on a powerboat.
Stick a soft antifouling on a fast powerboat and it'll erode away very quickly.
Stick a hard antifouling on a slow yacht and it won't erode away much at all. To add insult to injury, the surface layer will eventually leach out all its algicides and without erosion, no new algicide will be able to get out - the result is slime/weed/barnacle growth. Racing yachts may use a hard antifouling, but will usually be lifted out during the season in order to scub off any slime build-up - and usually expose new algicide by scraping off the top, inactive, layers.
* there are probably exceptions...
Thanks to everyone for the advice. It's only its second A/F the first coat was on it when I bought it brand new and it didn't behave the way the current coat is.
Did you know what was used last time? Some are incompatible and it could fall off as a result.
I will try the rubbing the transom idea. It does seem "knobely" still on the small bit that I rubbed that caused all the streaky mess in the water. I don't think it will go back to the gel coat but maybe it is going back to last years coat?
If it goes back to last years, that probably would be inactive and it might as well go back to gelcoat. You'll always be left with a residure though unless steps were taken to remove all traces back to the gel coat.
Many of the boats around me have blue A/F but also some blue in the colour scheme. As you can probably see my boat is all white. Do you think blue A/F would look OK?
Personal opnion I'd say. If it were me, I'd stick to white. It doesn't work any better after all.
