yno
New Member
Hello,
I've recently purchased a 1969 Dufour Arpège and decided to peel the gelcoat to see what the hull and keel look like. Apart from a crack fore of the keel-hull joint there wasnt any negative signs ; no rust coming off the joint, no other significant crack, nuts look as good as new, etc. Nevertheless it is an old boat, and although a friend of mine suggested the keel rods and nuts were most likely replaced at some point, I somewhat doubt that. The nuts in the bilge were covered in resin which is an original design of this boat, and the resin looked as old and wore as the rest of the bildge. Most previous owners only seemed to have sailed it very occasionally, which would explain the state the boat is in, which I would consider pretty good considering its age. As you can see from the pictures, it would seem some parts of the joint were lacking this black goo (feels like some kind of resin), which I find quite odd. I am concerned about water getting in and compromising the rods. Otherwise most of the joint is perfectly sealed and doesnt show any sign of rust. The keel itself is cast iron and is of course pretty worn out although I reckon it probably still has quite a few years in it. It doesnt show any wear around where the rods go in so that's reassuring. The top of the keel seems to be protected by a few layers of laminate, however it is concave, so if any water was to get in there, it most likely would get stuck, and although the boat has been on the hard for 2 years, I have no way of knowing if it is wet for sure without dropping.
And so I am considering whether I want to drop this keel or not. The hull has a small indentation to embed the top of the keel, which I figure would make fitting some kind of chisel quite troublesome. Also the rods are at a slight angle, so I am guessing they'd have to be removed before the hull can be lifted off (I dont know if it adds any complexity or not).
You can find the full set of pictures in here :
Any advice would be greatly appreciated
