Duffer
I've regularly sailed shorthanded and found getting into a marina berth with a finger pontoon much easier with a short spring (attached to your centre cleat) with a fixed loop in the end which can be dropped over a suitable cleat by your crew using a boat hook. Gently motoring against it brings the boat nicely alongside while you sort out your other lines. You can thread the rope through flexible tubing to form the fixed loop and adding a rubber snubber to the spring also helps.
Due to regular crew having kids or cancer I had to chose to go solo or sell our 35' boat. I couldn't figure out how to steer, control the throttle and hook on the spring all at the same time. One suggestion was to use the same arrangement with fixed loop as a short stern line. As I normally reverse in to my berth (most modern AWBs reverse very accurately) I can stop the boat the required distance off the end of the berth with the engine, drop the loop over a suitable cleat and gently motor against it which again holds the boat alongside while I sort out the other lines. If the wind or tide are coming from the end of your berth then there is no real problem, if they are pushing you onto the end of your berth, or off your finger pontoon then you need to be much more careful and e.g. consider asking for help or leaving it until later. If you try this method I suggest you practise a few times with no wind or tide first!
Apologies to anyone who has been doing this for years - I haven't seen it mentioned before. There is an article about this method by Tony Edwards in the current Dufour News of the Dufour Owners Association. PS this assumes you have sensible cleats around your marina berth - unlike short bouncy French finger pontoons with only metal tubing to attach to!
Do you have any tips on this or other aspects of single-handed sailing? Somewhat to my surprise I quite enjoy going solo - it feels quite liberating!
