Sheared bolt
Oily Rag
27 Jan 2016
Said bolt sheared not when I tried to remove it, but because the bracket is supports was loose and it gave it a smack.
So: bolt shank left in is probably still free to turn. Probably not seized.
My concern is that if I try to drill it out, it will rotate and make its way to the other end of the hole. And then drop into the inlet manifold!
My query is whether drills are available that work in anti-clockwise direction.
Any toolmakers clocked on tonight?
greeny
15 Jun 2004
Portugal
You don't mention the diameter but if it's free to rotate and you can get at it, then tap it anticlockwise gently with centre punch until you can grip it with something.
William_H
28 Jul 2003
West Australia
I would risk it screwing in when drilling. I think if you have lots of pressure on drill then this will translate to grip on thread so not turn. Just monitor very carefully to see if it is in fact screwing in while drilling. Use a small drill and small extractor. ol'will
