jac
Lewmar do a very good video on how to service a winch .
see how much they apply!!
Any that gets on the deck is definitely excess....Do the below look excessively greased, please?
Related previous thread for those who missed it: Barient winches: 28 vs 28+ models - what's the difference?
He is extremely frugal with grease and doesn't squeeze any out of the tube. I'd use a tad more than thatLewmar do a very good video on how to service a winch .
I may be misreading the photo but the roller bearings look a bit dry. The rest, definitely overdone.
One lesson I have learned is that when lifting the drum off, put a hand underneath. Otherwise the bearings that are between the drum and the spindle drop out unexpectedly and may bounce off the deck into the water. Ask me how I know!
TudorSailor
I have to say that it reassured me - I found the video a few years ago with a new to me boat as was struggling to get the drum off and thought i had missed something so watched the video to ensure i wasn't being an idiot. ( I wasn't in this case!!) Without seeing this i would have over greasedThe video has completely changed my idea of 'lightly greasing'!
Well, thanks for the thread, it reminded me that my winches were due a bit of TLC. Three 50 year old winches in Tuphnol(?) and bronze - Barton? They turn a lot easier now, with a firm click as the pawls go over the ratchet teeth. I even managed to get the pawls in the right way round after a couple of tries! The hard bit was getting the old grease out with white spirit (all I had) and a toothbrush
Doesn't seem to make complete sense. I would expect a greased surface to trap grit etc, and that to be independant of the grease thickness. IOW I wouldnt expect thicker grease to trap much moreReason for not smothering in grease .....
Grease captures and holds salt / crud / any grit and can actually lead to it doing damage. Light smear is less likely to do that. Second - the excess actually never does anything except just be excess !
OTOH once its trapped, thicker grease might tend to dilute the grit a bit and render it less damaging.
OTOOH, the old hard grease was a pain to remove, so I didn't put very much back on the two old Tuphnol/bronze ones I did this afternoon, but I supplemented it with PTFE thread tape wrapped around the central pedestal. These winches didnt have roller bearings, just this plain bearing surface.
