corto-armitage
New Member
Thanks a lot for your input. I had though 3 layers of 300 g because we removed 3 of 450 g mat on the rationale that they usually say biaxial is "much stronger" than mat. One of my 3 partners insists on 2 (and tends towards the theory which also is common that the old boat is thick and would be fine even if we didn't do anything). What you're saying makes me think maybe 2 layers of 300 g and 1 600 g, or 4 of 300 g, plus reinforcing the stress points.
I'd certainly like to get back to you when I have had other readings, have had the boat sounded for delamination and figured out more precisely the thickness of the boat in the various areas before and at the woven roving. In the meantime I was wondering if you could help me with the following:
1. Did you do the work yourself or the boatyard? How did you / they go about doing it? (West System suggests laying the sheet flat, soak it, roll it on a plastic tube, unroll it on the surface of the boat)
2. The reason I was thinking 300 g is that they've told me that above that (one said 200 one said 400, so I averaged it out) it is more likely to fall of when you attach it overhead. How did the 600 g work out?
