ChrisE
Its all very subjective, though, don't you think?
We have a centre cockpit yacht and fitted a hydrovane and have a tiller pilot for light airs. Our second Atlantic trip with the two of us was bliss after the problems with a belt driven autopilot on our first circuit. Often two handed and sometimes four and with the autopilot mostly broken we hand steered an awful lot. 3 hours on, 3 off for a few weeks means you get really good at it!! Also inventive in taking a leak......
Have taken a yacht transat a couple of times with a full crew, got them to steer by hand for practice but nice knowing a good autopilot was available. Once on the return trip however with fewer on board, the engine starter motor packed in so went for nearly a week to the azores with no electric, do consider that.
Have taken another boat over 3 up, belt broke 3 days from Antigua, spent hours trying to mend it, gave up. Same boat on way back blew exhaust flange on heat exchanger, 4 days hand steering 3 up.
Also had 2 completely incident free trips auto all the way!!
Delivered a yacht from Lanzarotte to Solent, towed generator. Have you ever tried to recover one when the wind gets up quickly? Need a flippin crane.
Hydrovane for me. You can offset them from centre with sugar scoop, works perfectly and you can still dangle yer tootsies!
Good sailing whatever you choose.
CS
We did 6000 miles with a towed generator and here's a few observations:
1. We lost about 1/2 - 1 knot boat speed when the wind was less than 15 or so knots, once above, hull speed was took over;
2. For a boat like ours with a fine stern, the generator acted as a bit of a drogue and held the boats bum into the following sea without the yawing that you get without it, thus we were able to do the transat with an under rated, cheap autopilot as it didn't have to keep bringing the stern back in line. Later, when we used the autopilot without the generator we trashed it in a couple of days of boisterous downwind sailing;
3. To get generator in when loaded is simple PROVIDED that you slide a funnel down the line to mask the turbine, alternatively you can, carefully mind, turn the engine on and slow the boat to make the operation more simple;
4. You get more than enough power to keep a fridge, autopilot and nav lights going with the batteries fully topped up.
We no longer use the generator as we now have both a Monitor windvane and a decent inboard autopilot. Like others we use the windvane for longer (>24 hour) offshore passages and the autopilot for short passages and light airs.
