Fascadale
I have two batteries, start and 85 amp hr leisure.
I want to increase the leisure capacity.
Should a second leisure battery be the same size as the original ?
The second battery will be fitted about a metre away from the original; is this OK and what sort of (size) cable should I use to connect the two?
Is there anything else I should be considering in relation to this?
