purplerobbie
I'm still working on the decks of my boat but i'm getting there.
I need to seal the margin board to the fiberglass of the hull.
I have bought this stuff called Eposeal which is a very thin (water like) epoxy.
My plan was to clean all the edges out. Then sand up the margin board and then put a couple of coats of this eposeal on the margin board and in the join.
Then fill the join with sikaflex.
Then go over the top with a few coats of colean.
My reason for using the eposeal is it will get in all the places the water could and seal them up.
Then if i seal over the seam between the hull and deck with the sikaflex this will hopefully keep the water out of it.
Then if i cover the lot with colean it should last a good while.
The problem i now have is i have just been told that there is no point in putting epoxy on wood as it only last a couple of years then it breaks down?
Is there any truth in this?
Does anyone have any better thoughts?
Rob
Rob
