Seafarer Sounders
Ive heard that the length of the coax is critical between the sender and display unit, does anyone know this measurement and what rating coax should be used ?
Thanks in advance as someone out there knows.
Yes,the coaxial length is fairly critical.this is because the transducer is tuned to the output stage of the sender,you can take the unit to a competent person and with the use of test equipment can tune it for you.But try it ,see if you get a reading or response it may be ok.
double trouble
