citygent111
Hi all, Alpha one gen 2 outdrive. Trim down works and trailer up works, but trim up doesn't. It used to!
The trim limit switch on the outdrive has been cleaned up but still no trim up.
The trim sender doesn't work as there is no disc inside the switch, so trim gauge on the dashboard doesn't work, but I'm not bothered about this.
I've been reading about bypassing the trim limit to establish what the problem could be, but wondered if anyone has experience of this and could explain in simple terms what I need to do?
The only guides I've found say to disconnect the two wires and connect them together, but then I read they are both male connectors so how does that work?!
Thanks in advance for any guidance.
