geem
When I changed a 1.5" valve in the water on my last boat, we jammed a piece of stainless steel into the through hull so it caught on the two little bumps in there. A put my mole grips on the stainless to hold the through hull, then my pal turned the seacock inside the boat with waterpump pliers. Once we had the seacock loose, without the through hull turning, we removed the file and taped a wooded bung in. We screwed on a new valve then did the same trick with the piece of stainless to tighten the valve. Worked fine but a bit nerve rackingps plumbers trick - if water is coming in - you will only screw a valve onto the hull fitment if the valve is in the open position. works even with cold water mains pressure on land. hopefully your seacock is not too deep.
(i have also changed seacocks by putting my thumb over the hull fitment on the inside, after unscrewing the old seacock. only 1-2 litres came in.)
