jimi
Are these any good, if one is not normally constained by draught should they be avoided and preference given to a proper fin?
I had a good conversation in Newton Ferrars a year or so ago with a bloke who had a particularly stunning blue hulled Starlight 35....
He had the Scheel keel on her when purchased... then swapped for a deep fin after he took up racing.. He felt they were at a odvious though very slight disadvantage racing with the scheel... but that for cruising it was a better bet due to the shoal draft....
So I guess it just depends on how preformance oriented you are.... I suspect that it also depends what boat you are purchasing... Ie if its a Sadler then there is a ready market for the boats with that keel... its a known quantity... but possibly at a disadvantage on others?.......
I would have one without hesitation... if I was looking for a Starlight 35 or Sadler 34 it would be miy prefered choice.... I doubt you would notice the difference in preformance...
Very useful for avoiding marina charges.
Think you will find that keel is a Stephen Jones designed wing keel, not a Scheel. The latter are a very specific shape of bulb designed by (you've guessed it) a Mr Scheel. They were quite popular on Moodys in the 80's as they gave shallow draft without going the then popular route of twin keels.
The large horizontal surface sucks itself tight in muddy seabeds. So freeing yourself can be an issue.
The boat pointed well, was pretty fast for a 28 ftr and the keel never fell off, what more can you ask for?
I've tried to put this 'suction' thing to bed before, so here's another go.
Take an 8 metre sailing boat with a winged keel, span 1 metre, average chord 1m. Horizontal area is 1 sqm. Waterplane area of the boat is 12 sqm. Keel draft 1m. Displacement 1,000Kg.
Park it above mud and let the tide go out. Total force pushing the keel into the mud is 1,000Kg. This must have been soft mud, but let the tide go out a long way, and some of the water content of the mud also run away to make it a bit more aggressive.
When the tide comes back in as far as the designed waterline, there is now 1,000Kg lifting the boat. But the mud's gone stiff. So the wing now needs to lift the cubic metre of mud above it. Being pessimistic, lets say another 1,000Kg. Waterplane area is 12sqm, so for 1,000Kg the rise of water needs to be a further 1/12m = 80mm.
Freeboard of this boat is likely to be 0.5m or more.
This would give a volume of 6 cubic metres, equivalent to 6,000Kg before downflooding occurs.
You'd need some pretty fancy mud for that not to overcome the suction.
Running aground with these kind of keels can be quite an experience, so I've been told. The large horizontal surface sucks itself tight in muddy seabeds. So freeing yourself can be an issue.
Then again, because of the smaller draught, the risk of grounding may be smaller as well.
just my 2 cents....
We had a Sheel keel on our last boat, an Etap 28i, on our first channel crossing we sailed in company with a Gibsea 33, a Maxi 34 and an Etap 30. We all left the same time, but we were the first to tie up in Cherbourg.
