List of bilge keel boats, 27 to 33ft or so?
Tranona
10 Nov 2007
Moody if you want space. The Angus Primrose designs are tough and roomy.
Actually of the Primrose designs only the 29 was made with bilge keels and although a bilge keel 33 and 36 were listed I don't think many if any were actually made. Never seen one for sale. The next generation of Bill Dixon designed boats had bilge keel options that were very popular - 27, 28, 31 and 34, 346
dgadee
13 Oct 2010
Seawolf 30, designed and built by David Feltham, after designing various Colvics, the Mirage and the Cobra
Seawolf is wide with good deck space and internal space. Designed as racer/cruiser and works well in both roles. Mine is twin keel and - when I do bother to race it - it does well. Rig the same size as a Fulmar, so very good light weather performance.
There are tatty ones about and a small number not tatty. I think only 10 were built (I have been told).
I bought mine after viewing a Sadler 29. Much more space.
Tranona
10 Nov 2007
That's the kind of suggestion we were looking for.
We're aware of the obvious ones listed in the OP.
Are there not some French twin keel boats? One or two of the mainstream builders as well as RM?
Probably newer and OTT on price?
It doesn't seem easy or effective to search for 'twin keel yacht for sail'.
By the way the issue with 'tall people' is not so much about headroom. Saloon berth length seems limited with many boats?
There is just a huge range potentially available. Forget the French - as you say the few that are made are more modern and not seen in the UK. you are looking at 1960-80s British boat up to 35' or so which will get you just about all of the Westerlys up to 34', the Bill Dixon designed Moodys, all Cobras/Seawolfs, Colvics in various sizes up to 36', Sadler 26 and 29, UK Hunters up to 32'. Many more smaller less well known designs that I have forgotten but might pop up into my mind later. Some, particularly the earlier designs are older style (comparatively) heavier boats like the Westerly 31 and 33 hulls available in a wide range of rig/keel/cabin configurations but later ones like the Moodys, Sadlers, 1980s Westerlys and Hunters are more modern with better sailing performance. Anything 28' and above would fit your basic requirements, which are exactly what most of them were designed for in period.
fredrussell
24 Mar 2015
Has anyone mentioned Kelt 29 yet? Swing keel, dries out on a cast iron ‘shoe’ so no need to worry about the state of the sea bed. Aft cabin too, which many of the older British boats in this budget will not have.
Daydream believer
6 Oct 2012
Southminster, essex
Isn't it odd how the Op asks for details of bilge keel boats & forumites go on to tell him that he never wanted bilge keel in the first place, so here is a lifting keel design.( yes I know about #4)
It was only 4 posts before a singe keel cropped up. So I suspect that it will not be long before someone suggests a fin keeler- well they do sail better :D :rolleyes:
B27
26 Jul 2023
I was expecting to be told two keels must mean two hulls or at least two masts.
dgadee
13 Oct 2010
I should say we have three boats at present, planning to go down to two. Idea was the Fulmar was mid size, and I like it. But the crew prefers the Seawolf. More deck space she says and not such a caravan size.
We have won the same cup (huge!) with both boats, over two years.
kwb78
8 Jun 2005
Leisure 28
Leisure didn’t make a 28, but they did make the 27 in fin keel and bilge keel versions. There is also a 29, which is effectively the same boat with an extra 2 feet in the cockpit. There weren’t that many 29s built but most of them were bilge keeled. The same moulds were later used to produce the Lynx 29.
Dellquay13
19 Feb 2021
Boat at Milford Haven, Home in Chesterfield
HH27 TK is a more open layout, larger version my my HH23
I looked at a HH272 the other week, it felt a lot more like a 26’ with a sugar scoop extension than a 27’. It didn’t have much more volume than my 24’ after considering it was very much open plan to maximise what it did have. Most had self taking jibs too, which put me off.
The Seawolf 30 has a more modern layout with an aft double and aft heads, most British bilge keelers I have looked at have forward heads and aft pilot berths.
B27
26 Jul 2023
Thanks.
There's a Leisure 29 in Suffolk on ApolloDuck, recent engine £12k
dgadee
13 Oct 2010
That is the later Seawolf. Most have the traditional pilot berth.
B27
26 Jul 2023
The Horizon 27 is pretty much exactly a 26 with stern extended over the rudder.
The extra space is pretty much in the 'low profile' 'aft cabin' which isn't an enticing space for the larger humanoid.
The settee berths are not very long.
Mostly underpowered by 1GM's.
The self tacking jib is not such a big negative as they are fractional with a fair sized main.
I looked at a couple a few years ago, blue grp interior and kit-built woodwork were negatives on those I saw.
Daydream believer
6 Oct 2012
Southminster, essex
Thanks.
I thought it was a 28 but I checked & a friend of mine says he has the 27. He has cruised round the top of the UK and to Brest, from the east coast, plus up the Dutch canals. Like all bilge keelers it suffers a bit in chop to windward. On a recent cruise to the Solent for 14 days he only used the engine to get into ports. His average sailing speed was 5.5kts which I think is a good average for a 27ft bilge keeler. Some of the weather was a good F7+ He has it loaded with cruising gear, often sails SH but sometimes goes 3 up. The boat could do 4 but he has altered his berths as he takes bikes etc.
Sailing steve
4 Apr 2021
There's significantly more internal room in the Hunter Rangers compared with the earlier Horizon equivalents.
PetiteFleur
29 Feb 2008
Suffolk
Moody 33mk2 - better than the mk1, in my opinion, centre cockpit, roomy accommodation, sails well and will keep you safe in poor weather. Not many bilge keels made though. I'm biased of course as I have the mk2 - should be able to get one for your budget.
