oldmanofthehills
Jack Sound slack is about 2 hours after HW or Low water. I have had an interesting time going through to early due to failure to amend for BST and as a result came through at 14kt when engine on idle result in almighting splash when boat hit still water. So next time I went via Stockholm, and like you hit vertical waves of 4m. Much splashing and alarm but nothing landed in the cockpit.Hi Everyone,
I seem to get caught out with overfalls or underestimate how bad they can be which is why im doing my homework on them.
Just some cases- back in April i was sailing around the isle of man, We took Chicken Rock - about 1 mils outside the overfalls on the chart but they was still rough
Just before Christmas we was heading down from Caernarfon to Pwllheli stayed on the outside on The Tripods - about 1 mile again and was rough.
Both these times was with tide heading in the direction we was sailing and light winds - They was doable and not to bad but was rough for 20/30 minutes. - Devils ridge was flat.
We have just left Fisgard (17th Jan) to Milford Marina. Winds about 13kts to 18kts southerly, spring tide. Everything was great, really good sail up to St David's, we went through St Georges Channel which i was aware of and knew it was going to get choppy but choppy was an understatement. We was motor sailing and it was that rough the engine failed which I'm assuming was a fuel issue. it came back on shortly after with no issues.
We crosses the bay, motor sailing, and tide pushing us. I was going to go through Jack sound as we should have hit their at low water slack, but the wind was a bit high and the conditions we just had i changed my mind to go around Skomer and go through Broad Sound, Again i took this wide, about 1-2 miles outside the overfalls on the charts. It looks choppy so i decided to go around Stockholm (Wild goose race). This was a disaster. We get F***ed. Massive waves easily 4-5m. Towering. Engine failed multiple times as i tried to hit them on the shoulder. Was a sh*t show. Completely my fault for under estimating them. But this is the first time i feel like i badly messed up and put us in danger. Jack sound should have been low water slack but i was going at 11.8kts at this point. The tide was ripping. I had an anchorage on the north side on Skomer which at this point was only 1.5miles away so we tried to turn back, i was doing 1kt with engine at full speed. We had to turn into it. I decided to head out further to hopefully get out the overfalls. 20,30 minutes of slamming and battling the waves they finally settled down. Luckily i had the sail out reefed which kept steering when the engine failed.
Luckily we are all good and no damage to the boat, the inside was a mess with a few things broken that got flung about.
I don't want to make this mistake again. I wanted to see what yous do, do you avoid overfalls, do you time them for slack water? My thoughts at the moment is to go miles (3/4 if not more) around them. I need to know what's the best approach to these as i can see im going to encounter a lot around the Bristol Channel and south of the UK.
Also, just FYI, we both had a PLB on us and both Harnesses in. But i hope to never get to the point where im thinking we need to use it. Also when i say caught out on overfalls - I mean it like understate them. I am fully aware of them on the charts when i do my planning.
Thanks in advanced.
Since then I go correctly through Jack near passage slack or plan my route via Broad Sound more carefully.
In fair weather and daylight few races are that much of an issue, except Portland and Shambles, as one can see to avoid the worst and often sneak inside them. Poor weather and poor visibility needs one to keep well away
