bugs
I replaced my anode towards the end of the season and found the new one quite loose by the end of the year.
Assuming i can break the bondlock seal (i hear heat works) on the propellor studs, I intend replacing the anode.
I tightened the anode the previous time so I am now considering insulating the bolt (assuming I have good contact elsewhere) to prevent the erosion at the bolt area. Alternatively I thought of includingspring washers or spring to take up any play as it erodes.
Any thoughts on either approach. The anode appeared to be reasonable eroded- ie not excessive just happened to do so at the bolt area resulting in looseness which I assume results in poor contact in addition to unwanted vibration etc.
