ropeworkuk
I would like to ask for help in putting together a sail trim table that i can laminate and use as a reference guide while sailing.
I have attached a table of what i think is correct for:
Main sail
Genoa
in both good wind F3 and above and light wing F3 and below
There are plenty of sections on my table that i'm not sure about?
Please could you have a look and fill in your recomendations in red so that i can see the changes?
Thanks in advance
MAIN SAIL
Cunningham Out haul Kicker Sheet Traveller Back stay
Wind F3>
Close haul tight tight tight In close ? Tight
Beam reach tight tight tight In close ? Tight
Broad reach loose loose ? out ? Off
Run loose loose ? out ? off
Wind F3<
Close haul loose loose Moderate In close ? Off
Beam reach loose loose Moderate In close ? Off
Broad reach loose loose Moderate out ? Off
Run loose loose moderate Out ? Off
GENOA
Halyard Sheet lead Sheet Leech line
Wind F3>
Close haul tight ? In close ?
Beam reach tight ? In close ?
Broad reach tight ? Out ?
Run tight ? Out ?
Wind F3<
Close haul loose ? In close ?
Beam reach loose ? In close ?
Broad reach loose ? out ?
Run loose ? Out ?
Main sail
Genoa
Thanks in advance
MAIN SAIL
Wind F3>
Wind F3<
GENOA
Wind F3>
Run tight ? Out ?
Wind F3<
Run loose ? Out ?
