Halo
Gong back to my days studying tribology I would say if there is no deterioration in the oil colour (indicating water) then, in a sealed system such as a sail drive , what you are really looking for is
- to check for debris which may indicate a failing or wearing part
- to put in clean oil which does not have the microscopic particles which arise from wear and rapidly cause further wear.
In both of these cases it is better to drain from the bottom of the sail drive leg.
What I do in practice is to drain from the bottom when I am out of the water. If I dont come out of the water I dont change the oil. If there is water present (cloudy emulsified oil then she needs to come out for a shaft seal change).
The surprising thing is how long you can keep draining out the oil. It will keep dripping out for hours - so set up a good catching system (in my case large bucket raised to surround the leg with a double plastic sack inside. I raise the bucket so the wind does not blow the dangly oil threads all over the place as they emerge ) and leave it to drain for at least 24h.
Make sure you examine the oil for debris (normally by straining it)
