Sail cleaning in a hot tub
SlimRick
17 May 2011
Weymouth / Trowbridge
Is it worth a try?
We have an inflatable hot tub in the garage, and a set of grubby sails. If is set the temp to 40’, throw in some non-bio washing powder, put the sails in and turn the bubbles on for half an hour.
Chances of success or abject failure?
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I think it will work better if they have had a good long soak. The bubbles will just get trapped by the sail and push it up above water level, soaking the garage floor.
Soak them and then clean with a soft brush on a flat surface. Hang them up and rinse with a hose with a a low pressure jet.
If they are good sails then the cost of a professional laundering is worth it IMO as they washed flat and checked over carefully. £80 incl VAT when I had my genoa done recently.
Heckler
24 Feb 2003
Professional cleaning? Our local people used to take them to an industrial outfit who were workware hirers and cleaners. They would go in an industrial washing machine.
Maybe an owner would do as good as with a gentle wash as described?
Stu
VicS
13 Jul 2002
Stu
Two of your "local people"; The Boatshed and JKA Sailmakers , send them to Tip Top sail Laundry. Their traditional methods were featured in PBO a while back
Heckler
24 Feb 2003
I have two "local" now, here and Gib! No names, no comeback!
Stu
MoodySabre
24 Oct 2006
Stu
I think he would but I wouldn't put my sails in a machine. Dolphin wash them flat and they come back in excellent nick.
pvb
16 May 2001
UK East Coast
Is it worth a try?
For success, you'd need a couple of scantily-clad ladies in there too, to keep submerging the sails.
Fossil
31 Oct 2012
Paekakariki, New Zealand
Irresistibly reminded of a poem by the late Bob Mackay of Welsh hang-gliding fame:-
Sails can be washed
(If wash them you must)
In water that's soapy and wettish.
I wash mine a lot
But then I have got
A soapy hot water fetish ...
Pasarell
18 Jan 2007
Greece
My local place, in Greece, wash sails by laying them out on the concrete outside their office and pressure washing with 2 men walking over them in boots to do it. They're not getting my sails but they were busy all last winter so plenty of people are obviously happy with it
Hydrozoan
11 Apr 2013
I suspect much would depend on the nature of the dirt. I had considerable success, following advice on this forum, with Biotex (no connection etc.) in removing black hydrocarbon deposits from the atmosphere when other methods (including a professional launder) had largely failed. I used hot water in a bin for about 24h, with occasional agitation of the (heavily folded) sail. A larger container allowing better agitation might help, though it would need more detergent to maintain the concentration. I found it necessary to rub residual black marks after the soaking, but the detergent had certainly 'loosened' them effectively.
stephen_h
4 Aug 2009
For hard to remove stains try coating with lemon juice, sprinkle on some salt and leave in the sun - if you can find any!
