sail area/ displacement ratio
boatless
1 Mar 2004
'Light ship' displacement in Kgs divided by area of main and 100% foretriangle in square metres will give you a comparison with magazine tests.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
the formula usually used is
SA/((displ)^(2/3))
where SA is sail area in sq ft
displ is "hull volume" in cubic feet--> displacement in pounds divided into 64 for salt water, this is raised to two third power, which means you square it and then take the cubic root
snowleopard
Oxford
<A target="_blank" HREF=http://www.sailingusa.info/cal__sad_ratio.htm>Here </A>is a site that explains it all very well and does the calcs for you.
dickh
8 Feb 2002
Suffolk
I've just done mine - "High Performance Racer!!" - Jaguar 27! - Ellen Mcarthur here I come!
Just double checked - it's only a 'cruiser racer'.........
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
joeh
4 Feb 2003
asia
i understand that the conventional rule says that u shld use 100% foretriangle when using the formula but any headsail aft of the mast is there right ? it is power and should be used in a power to weight ratio . especially so when trying to compare overlapping / non overlapping jibs, masthead/ fractional boats. i used both measures and they produce quite different ratios for a masthead.
AlexL
24 Jan 2003
East Coast
apparently -(YM or PBO had an article recently) the sail area is the 100% foretriangle i.e 1/2*J*I plus the main triangle with all roach removed ie. 1/2*P*E
dulcibella
26 Jun 2003
Portsmouth, UK
blog.mailasail.com
I got a negative value for AVS on a Rustler 36 until I realised I'd put in a daft figure for hull draft. After correction it came out as a credible 154. Garbage In Garbage Out ....
