RubyII
Active Member
Does anybody know where I can find editable and printable sailing boat safety check card ! Something fairly simple so crew know where to find more information should something be missed basic crew briefing. Thanks
Why not just write your own list? If you need it to be editable and printable you can start with a blank sheet.Does anybody know where I can find editable and printable sailing boat safety check card ! Something fairly simple so crew know where to find more information should something be missed basic crew briefing. Thanks
You probably are right I was just looking for a quick fix sounds like a Winter job ! ??As said make your own. One kind of safety card should list all safety gear showing location. The next to each item any instructions on use. ie VHF radio how to make a distress call. This list will normally be posted on a bulkhead.
Second kind is a checklist one for departure one for pack up before leaving boat. Aircraft have a lot of check lists. Used to be in a plastic box with each item covered or exposed by a slider. So you physically cover each item as it is dealt with until none are exposed. Now days all done on screen. ol'will
