Rusty trailer- which zinc spray to use?
Sea Change
13 Feb 2014
Not exactly a boaty question, but I'm fixing up a little garden trailer just now and noticed some superficial rust on the (galvanised) mudguards etc.
I've not had great results with zinc spray before but maybe I wasn't buying the right stuff.
Any recommendations for which ones are any good? I gather it's all about the zinc content but in finding it surprisingly hard to get numbers for most of the cans I've seen on sale.
Just spraying rust with zinc paint is a waste of time and money,
You need to remove the rust and treat with a rust converter first.
Sorry I didn't mean that I would just spray over existing rust, obviously I'll wire brush it back first.
Trying trying to find out which spray has the most zinc, and which ones are just silver paint!
Wire brushing alone is unlikely to be satisfactory. I have had good results with Fertan rust converter.
Regarding zinc rich paint .I remember my father having good results with Galvafroid many decades ago. The dry film contains 90% zinc by weight.
Wire brushing is also a waste of time, it leaves you with polished rust. You need something more abrasive.
I'm a bit worried that anything more aggressive might not leave much of the thin metal behind!
I'm mostly doing this for cosmetic purposes so that the plod don't feel the need to take too close a look at me...
Yes, it's all about zinc content, and you are going to get much more of it in the dry paint film if you use a cold galvanising paint applied by brush rather than spray can.
The best way is to grit blast the trailer frame then have the frame hot dipped galvanized for a long-lasting result.
I have a boat trailor thwt I plan to treat it the same way
I'm sure you're right, but this is just a quick fix so that I can do a couple of jobs with this trailer.
The actual drawbar and axle are in pretty good condition, the suspension units have a lot of flaking surface rust but seem solid, and the body panels have isolated rust patches that I want to treat before they get any worse and rust right through.
I use Jenolite for this. Other products also available from reputable suppliers eg Dinitrol. The key this as said by others is to use a product that converts the rust into a stable surface that can then be primed and painted. This conversion of the surface from a rusty corroded mess to something that you can reasonably expect to be painted is critically important to ensuring a long lasting fix.
As far as finishes is concerned, I favour the Hammerite products as mentioned above. Use a zinc phosphate primer first, then a couple of coats of your preferred finish. Some finishes require lacquer over the top. Another point to mention is do not attempt to do this when the temperature is lower than the figure recommended by the paint manufacturer, this will inevitably result in a lower quality outcome.
Haven't had success with spray cans but Smith and Allen zinc rich paint is long lasting. Very high zinc content and lasts for many years in my experience. Also whilst wire brusbing isn't recommended I find the zinc rich adheres without a problem. I've succesfully used a wire brush on an angle grinder. You could hand sand after the wire brushing to leave a somewhat rougher surface.
