Running engine (diesel) with the ignition turned off
Status
Not open for further replies.
VicS
13 Jul 2002
Whereas I agree with you ........................
The compression ratio in an internal combustion engine is determined by .........................
What is your definition of compression ratio... I keep asking but you do not answer the question
PaulRainbow
16 May 2016
Suffolk
Whereas I agree with you that a few individuals on this topic are sarcastic by nature, and it's not a quality that I value very highly, your last posts are falling apart so much in the use of English, that I can't follow them.
Funnily enough, if often tends to happen when we are attempting to be smart arses. It's like the sub-conscious kicks on to trip their egos up and has them make a fool of themselves. No idea what you are referring to now.
The compression ratio in an internal combustion engine is determined by a combination of the shape of the piston and combustion chamber because, in combination they then determine what Vc is. That is "shape" as in dimensions, not the "kind of shape" as others have attempting to assert, in order to confuse the issue and protect they and their friend's egos by burying the stupidity of the original comments and arguments behind noise and cruft.
I am not suggesting that the original "Emperor" has "no clothes on", but he certain dropped his pants in public and prove he has a small pee-pee in this department.
How old are you, 5 ?
Hadenough
9 Jan 2011
No fixed abode
In some reality it must ...... just not in this one. o_O
Richard
I used to have a Lambreta LD 125. Petrol was 12/6 a gallon and I used to ”fill up” by the pint and squirt an bit of two stroke oil into the tank. Girlfriends house was 5miles away and I often used to get home on whatever was available, paraffin, straight petrol, vodka. Dunno what shape the pistons were but I never walked home?
convey
N/A
26 Jun 2020
That's because compression ratio is defined by the shape of the piston... I mean, in some reality it must?
I preferred to write determined.
Yup, in every internal combustion chamber, steam engine, and air compressor. In combination with the dimensions of the other parts mentioned, of course.
Do you really find it that difficult to understand? It must have taken a life time's worth of practise to become that stupid.
NotBirdseye
13 Apr 2019
Wales
When qualified engineers, aerospace engineers and professional engineering bodies (NSPE, theIET and RAEng) are telling me that it's not... but instead point me almost universally to the equation... (RAEng posted a diagram)...
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
We're getting there, again .... although we did that a couple of times before and then you started backtracking to that "shape of the piston determines the compression ratio" nonsense. o_O
Anyway, we're now effectively back at my post #418: "What determines the "volume at the end of the compression stroke"? The engine designer" .
Excellento. (y)
Richard
rogerthebodger
3 Nov 2001
He offered to go to the IMechE to adjudicate the two positions when I said let's go with several C Eng's and myself as an ex MIMechE on here that was no more talk of that.
Status
