Hoolie
It seems to me, given your limited power resources, you should be considering a more modest solution to your needs!
Google drive might be worth a look, looks like a separate drive or point it to various folders. Then forget about it, you won't know it's there, just keeps your files updated when there's web access. 16Gb free with each email account or 200Gb for 2-.50 a month.(Yes, I know I should keep files on a cloud server but I don't . . . )
The PC will not require external storage, just kb, monitor and mouseAsking how long a PC of whatever type will run on a power source is "How long is a piece of string" ...
Add an external drive ... storage ... etc and the power consumption can dramatically change ...
The figures being quoted i.e. the AMD processor 45w, and the power supply numbers are absolute maximum numbers. In practice it won't be drawing anywhere near those numbers under most normal usage. Actual power consumption will go up and down based on how hard the machine is working, if you're only using it for things like email, web browsing etc. then it will hardly rise above idle power. Chances are the monitor you connect it to will be using more power than the machine itself.
Have you considered that there are ways of installing win11 on laptops which are “not compatible” ? Plenty of information online if you search.
I have 250W of solar and spend at least a couple of months in total plugged into shore power, so I am really not anticipating any problem. I certainly manage OK with the Thinkpad at the moment, but it is not Win11 compatible so will shortly be toast. It has a 4400mah battery. The Renogy power bank is 222Wh, but I have no idea how that compares.
At the moment I lug the laptop back and forward and use my desktop at home. The Geekcom will be lighter to carry and will replace both devices, which saves file transfers each time. (Yes, I know I should keep files on a cloud server but I don't . . . )
All I really want to know is, how long will I be able to run a Geekcom IT12 or A8 from the Renogy power bank, which I will essentially be using as the equivalent of the laptop battery. If I need a bigger power bank and have to buy more solar to charge it so be it. As I run a web design business your suggestions of modesty are not entirely sensible.
Hopefully Geekcom will get back to me with a quantitative answer.
Thankyou. This seems more realistic. My own suspicion is that the Renogy power supply will run the PC for many hours on a charge.
The Pi5 is much better for this, and has a proper GPU on board. It's quite usable for most tasks as a desktop but I wouldn't try video editing or anything heavyThis season I’ve set up a Pi4 8gb Ram as ships computer with Open plotter. It’s very good indeed - but only at doing one thing at a time.
I think you’d get frustrated very quickly indeed trying to run multiple applications at any given time as you would as a matter of course on a normal laptop.
Try an online calculator if you're not familiar with wiggly amps etc.Thanks wonkywinch, for pointing that out. I am not very good with power consumption calculations.
This Renogy 200W job for £130 has pure sine wave output up to 200W (allegedly). Renogy gear has a good reputation.
Renogy Portable Power Station 200
This is your lack of IT skills, not a problem with Office 365. The installer for O365 is identical to the installer for the other version, and both have JIT feature installs which you can force ahead of time if you so choose. The main difference between the two, is that O365 can be installed legally on multiple devices for the same user which is very useful for people with multiple laptops, desktops and mobile devices. It also comes with OneDrive so your documents are available across all of those devices if you so choose.What really brought it home was during an offshore job ... we had swapped out the on-board computer for the Superintendeent from a Office standalone full package .. to a 365 installed machine.
All fine for a few days and then 365 needed to connect to internet to download another part of package .. connection was very poor and machine basically failed ... we had to resort to back up of my travel Acer ONE till we could connect better and get 365 back up again.
It absolutely is legitimate. They operate by purchasing huge quantities of genuine licenses and selling them piecemeal.That's not a legitimate source, I suggest you remove it.
