KellysEye
Overtaking vessel must keep clear, covers everything including mobos, ships, yachts, navy, hovercraft and anything else you can think of.
However - assume overtaken boat is in centre of the channel and constrained / overtaking boat has to keep clear. If the channel is too narrow for the overtaking boat to pass then how does she pass?
There are sound signals in the ColRegs covering this, including covering the vessel ahead refusing to allow the other vessel to overtake.
Were you sailing or motoring ?Out in the Irish sea over the weekend and came across this scenario. We're 10m yacht, day time ,showing no lights or shapes. An oil tanker came apon us on a steady heading on our port side rear quarter. Who is the give way vessel and why? My reasoning is that he was a working vessel and we should give way. However it was argued he was the give way as he was not "working i.e. constrained by draught or manoeuvrability or fishing" and hence he was the give way vessel. We did not see any shapes on his bow. He was very big! Ta Nic
Indeed - maybe I should have said I don't understand the rationale as the rules are black and white, but this strikes me as one of those cases where IRPCS MAY be the wrong way round and in fact Constrained by Draught should trump over taking rather than vice versa - e.g. More like the rule that sailing vessels or <20m should impede.
But academic in any case but I've never understood the rationale.
How would the CBD know the vessel being overtaken could get out of the way. The IRPCS have to be the way around that they are.
Boo2
I got the pole down with a bit of a struggle (single-handed) and jybed out to sea clearing his stern by a large margin. Now I know I should have called on VHF to clarify but assumed he didn't have much option having taken on the pilot, and all. I suppose he was considered to be in a channel and had right of way, dunno really.
So I'm mulling over why didn't I pick up that VHF microphone ... at least I could have assured them I was going to get out of their way. Funny really ... mesmerised rabbit in the headlamps syndrome, perhaps.
I've always struggled with this one with regard to constrained by draught.
18 (d) (I) says that any vessel other than NUC / restricted in ability to manoeuvre shall avoid vessel constrained by draught.
It makes exceptions for 9 ( narrow channels) ,10 ( Traffic separation) and 13 ( Overtaking).
That suggests that 13 overrides 18. in other words Overtaking boat keeps clear.
( I/m assuming something like a 21m lighter making 10 knots down a channel that she is not constrained by with a 15 knot ship constrained by draft coming up behind) ignore VTS / bylaws
Irrelevant Boo. If the tanker was overtaking it doesnt matter. If the tanker was approaching from the port quarter but not overtaking then again it doesnt matter for two alternative reasons. . If the OP is sailing the tanker is give way. If the OP is motoring the tanker still has to give way - remember " if to starboard red appear, tis your duty to keep clear"
No you should not have called on VHF - the MCA are quite strong on that point. Calls can easily cause more confusion and they are a distraction. How do you know that the guy at the other end understands English, for example. It could be very noisy at his end. Transmission could be broken up. And all the time the distance is shortening. What has taking on a pilot got to do with his options or the colregs ? Its simple really. You are on a collison / near miss course, he isnt showing any signs of giving way so you make a large and obvious turn to avoid him.
The answer is:
1/ if constrained by draught you dont get yourself into that position in the first place
2/ If you do so, then you slow down to 10 kn
3/ if you cant do that and maintain control then I guuess thats a situation where you might use radar, but I cant see that position ever arrising.
Mind you I did come into Pompey once on the bridge of a ferry only to see in front of us at the narrowest point of the channel a yacht under sail ( with a blue ensign for the benefit of those who like such issues). 5 loud blasts later and he was still in the channel but had moved to the edge. I did ask the master what would have happened had he not moved and the master said, when he had stopped swearing, they would have run over him. No alternative.
When do the colregs say you should hold your course when reality says otherwise?Then the master would be prosecuted for manslaughter if he run him down...you can't go around running yachts down cos they are in your way....
I run a charter boat and yachts and all types of boats get in my way when I am stand on vessel, the regs say ' you must hold your course.' But reality says otherwise.
I know what the recommendations are, they have been discussed at length in various threads here, but VHF calls are not explicitly proscribed and sometimes they can be appropriate, asking for and giving intentions can only assist in some cases.No you should not have called on VHF - the MCA are quite strong on that point. Calls can easily cause more confusion and they are a distraction. How do you know that the guy at the other end understands English, for example. It could be very noisy at his end. Transmission could be broken up. And all the time the distance is shortening.
Nothing, I was just musing and wondering who was calling the shots.What has taking on a pilot got to do with his options or the colregs ?
Agreed, it's what I did.Its simple really. You are on a collison / near miss course, he isnt showing any signs of giving way so you make a large and obvious turn to avoid him.
