Steve_Jones
Continuing the cleaning theme..
It's about time many of the ropes got a good clean or replacement. I want to start with the main halyard and have read about a technique where you splice a thin'ish twine to the end of the halyard and then pull the halyard through (it's run internally through the mast) leaving the twine in place. After cleaning/replacing you simple reverse the technique, drawing the halyard effortlessly through the mast...
Seems simple, but is it really that straightforward, or am I going to end up with a halyard jammed half-way up the inside of the mast in a tangle? I'm not great with heights and so clearing jams atop the mast are to be avoided!!
Thanks again!
Thanks again!
