mjf
Over the holiday had a look at this craft.
Not sure if others have looked at the IPS fitted to a boat yet.
However I think Rodman have missed some of the point...or maybe manufactures have to build boats around the IPS from scratch and not simply fit this system to existing hulls.
On the Rodman the engines sit right aft with the drives where the steering gear would be on a conventional shaft drive boat.
Either side of the engines is void - completely wasted space.
The fuel and water tanks are under the saloon floor - where the engines are found normally.
So, you lose the big laz that is boat normally has.....
The IPS had better be v.good indeed to make up for the loss of important storage.
Anyone else seen this?
