Ameliarose
Anyone know if the Rocna Anchors advertised on ebay are genuine? They seem quite a bit cheaper than anywhere else even allowing for postage.
Can't answer that, what I can say is I seen two copy and nether had the Rocna boss.SVic - suppose you were a metals engineer wanting to copy an anchor, why would you 'forget' to engrave the maker's name on the bottom ?
Before they moved production to China the then Rocna (made in NZ) had no embossing nor engraving of the name in the rear of the heel. The anchor was then folded and welded. With the move to China the fluke was cast and the embossing was no real extra cost. The production was then moved from Shanghai (after the bendy shank fiasco when CMP came to the rescue) to Ningbo, where CMP have their chain factory, and they may have gone back to a fabricated fluke, which they then engraved. I'm not up to speed what the current process is for the fluke - but previous changes made no difference to performance.
Since CMP became involved there have been no reports, or not that I have seen, of anchor bent as a result of poor production, poor QC or inadequate choice of steel.
Why an anchor advertised and marketed under the name 'Rocna' but omits the embossing or engraving of the name on the product makes any difference in terms of copyright or design I cannot understand.
It might not be the compliment one wants - but when someone in China copies your product you are making something of a success, think Go-Pro - as just one example.
Jonathan
The issue of counterfeit Chinese products is an enormous problem. Everything from Yeti Coolers to Dooney and Bourke handbags are being copied by Chinese maufacturers who operate largely outside the reach of western copyright laws. in many cases these knock offs are exceptional cosmetically...but in the case of the handbag, nobody will likely know...in the case of the cooler your beer will get warmer faster than it should...in the case of a fake Rockna your five or six figure yacht could be damaged or sunk.
If Rockna has made a flawed business decision to relocate manufacturing to China to increase profit margins without factoring n the inevitable theft of intellectual property and forging that is sure to follow and now the market is flooded with copies the consumer will simply have to choose another brand that made different choices and doesn't suffer from this issue.
I agree with most of your points Jonathan, but I was looking for a reason to choose one over the other and this did it for me - http://www.petersmith.net.nz/boat-anchors/manson-supreme-anchor.php
I have flitted back and forth so may still change my mind!
Jonathan , over the years I think I must had read every posting Nolex and you have wrote when it comes to anchors, most of it make interesting reading, I won't say I agree with everything.As anyone with a good memory will be aware I'm not a fan of Rocna - I will not forgive for the bendy shank fiasco. But CMP have introduced some professionalism and I'll defend the genuine product against a knock off copy any day. There was no excuse for the bendy shanks and I'd steer anyone to another model - there are plenty to choose from - but I do take the moral high ground.
Anchors really do not cost much and will often outlast the yacht.
Jonathan
