Graham376
So 50% of time - 2 phones (his & hers) could hack it![]()
Just have a local SIM so people in UK pay if they want to call you and use Whatsapp or Skype for outgoing calls.
I have a local SIM, but it's imperative I keep my UK mobile number for authentication purposes (bank, etc...).
To this end, I have a giffgaff PAYG SIM.
I dont remember how long it was. Obvious workaround is to have two or more SIMs active before leaving UK.How long is for a while![]()
That only works if you spend no more than 63 days at a time out of the UK. Then Giffgaff will cut you off, as will Three. If that's likely you're better to choose an operator that applies a surcharge and doesn't cut you off.I have a local SIM, but it's imperative I keep my UK mobile number for authentication purposes (bank, etc...).
That won't work either. If you leave them on, even intermittently, they'll both be cut off. If you keep one as a spare without using it, the number risks being cancelled due to lack of use.I dont remember how long it was. Obvious workaround is to have two or more SIMs active before leaving UK.
It's at least 6 months before they will cancel it as unused. Send a msg before that and it's another 6 months.That won't work either. If you leave them on, even intermittently, they'll both be cut off. If you keep one as a spare without using it, the number risks being cancelled due to lack of use.
How do you get the phones to and from the UK?
If you have a goodybag they say they will charge you extra for roaming after a while and in my experience they do.I would like to differ.
Haven't set foot in the UK for nearly two years now (since the start of this Covid madness), and haven't been cut off.
In fact, just had my daughter call me (from the UK) on my UK number to verify it still worked.
I don't think they bother checking where you are unless they only see a lot of calls constantly made when roaming.
I seem to recall tales of people being cut-off by Giffgaff, but clearly it works for you as you haven't been cut off yet. I was cut off by Three after about 16 months of being in France for the same reason! I suppose to be fair I do have an active Giffgaff SIM in my laptop - texting works but I don't think I've ever had PAYG data in France; the connection just doesn't authenticate. When I go back to France I'll leave some data on an active Goodybag and see if that works.I would like to differ.
Why not just move to O2. They have clearly stated that they will be including roaming long-term, and if you enter into a new contract with them, they are obliged to continue with those terms for the contract length. They include a max of 25GB roaming per month.Having left Vodafone to go to Voxi who included EU roaming they will now charge from the end of May . I am now going to 1Pmobile £15 for 30 Day 50GB data with a 14GB EU roaming limit then 1p a MB, uses the EE network in the UK.
Yes, we've been with VOXI for ages and get 100GB/ 30 days in UK. I knew we'd be restricted to 20GB in EU and might have some moderate charges after 2.5 months in Greece. Voxi used to say we'd get at least 2 weeks notice via SMS after 2 months. I had a text on 25th April to let me know it was changing from 27th May. I'll need to pay 2x£15 plus my £20 to get 20GB for 30 days. I suspect there will be other problems after 2 months in Greece.Having left Vodafone to go to Voxi who included EU roaming they will now charge from the end of May . I am now going to 1Pmobile £15 for 30 Day 50GB data with a 14GB EU roaming limit then 1p a MB, uses the EE network in the UK.
