Chris_Robb
I am in Greece and have been now for 3 years. So road diesel with bio (up to 10%) is used in the fuel.
I cleaned out the bottom of the tank using a scavenge pump, taking out about 20 litres or so into clear bottles until the fuel is totally clear. There was some black dirt that settled quickly to the bottom of the bottles, leaving a clear diesel above.
I then filtered the fuel back into the tank using a Racor filter funnel. I had to keep clearing the fine mesh filter - which is normal, but this year the stuff being cleared away was a tarry substance.
Is this the deposits from the Bio in the fuel as it settles over winter? I understood that this was the main reason why Bio should not be used in the marine environment.
If a tank is left un cleaned for only a few years this tarry mess is going to be a real menace, blocking filters in no time. I stress that I have no diesel bug in the tank.
May be this problem needs to be taken seriously now, or it may become a real threat to safety.
There is no additive that can be put in, so there is probably no alternative to an annual tank bottom scavenge.
