chrishelen
N/A
You can do it in the water,you need the new seacock at hand and just swop them around,if you are a bit slow and get water in the boat run the bilge pump,or if you prefer run the loose end of the pipe into the bilge and suck it all out with the engine,put your other halfs tights over the end of the pipe to stop any solids being sucked in. i have done this job a few times,preperation is the key.
