EyeCandy
Hello Bav34
The spacer/sleeve on my 39 fits between the rudder and the lower bearing, (not the housing) so tightening the top nut will put axial load on both the bearings and since they are spherical in their housings will "tighten" the steering.
The top nut I have has the clamping screw you describe plus two grub screws that further ensure this nut will not undo. This mod was suggested to me by my Bavaria dealer who apparently had experience of these nuts coming loose.
Before my rudder became tight I was able to lift the rudder up by slinging it with ropes through the aft mooring fairleads to the sheet winches. I suggest lifting the rudder with ropes then taking up the slack with the top nut. With the rudder up the nut can be adjusted by hand. You will have to get wet to sling the rudder but it is possible. When I took the rudder out last week I slung the rudder this way plus three lines around the rudder shaft at the top of the rudder. The boat was up in the slings and we had the rudder hanging underneath but clear of the hull so we could work on the bearings. With this experience I reckon we could do a bearing replacement while in the water albeit flat calm conditions. (but have a travel lift nearby too)
Andrew
Andrew
